NI TestStand
Exe file run problem
      I have two PC's and one PC is installed with LV2011 and other not. I created a simple Serial Communication VI and then created a exe file to use it on other PC where I don't have LV(LabVIEW). I read threads on this forum and I downloaded and installed LV run time engine 2011 on my other PC where I wish to run my EXE. Even though, the exe is asking LV run time again. Can some shed light on me about how can I run my EXE on my other PC where I don't have LV but installed Run time engine.
                                     Thank you.
(3,399 Views)
I forgot to attach the error message. Here it is.
(3,398 Views)
First of all, this is the wrong forum. This forum is for TestStand.
Second, why don't you create an installer on your development machine which contains the RTE? This makes sure that you have the correct version of the RTE available on the target once you have installed the package.
Norbert
Norbert
Expert: Geometry
(3,395 Views)
