NI TestStand
Execute Command liines from teststand
I'm trying to execute some commands usig cmd.exe in a TS sequence by the callexecutable step.
I've also followed instructions here:
https://forums.ni.com/t5/Example-Code/Display-and-execute-command-lines-from-within-a-TestStand/ta-p...
and ran the example there contained. However, I was not able to correctly execute a command.
Basically, what happens is that the command prompt is launched, but without any command.
Do you have an idea of what I'm doing wrong?
Thank you in davance.
Best Regards
(793 Views)
Been able to reproduce this using TS2019 32Bit
The article states to run an Argument Expression of
"/c ping " + "\" + "Microsoft.com" + "\"
This in fact results in a runtime error onmy machine since the backslashes are not escaped properly
Leaving them out, you'll see the cmd prompt executing.
In the second part of the tutorial STDOUT is redirected to a StepProperty Item.
Doing so will show you no cmd window at all.
Can you confirm this behaviour?
(784 Views)
my problem is already present at first step that should create a folder, but no folder is created, even changing the directory to work outside Disk C
(781 Views)
Accepted by topic author f6@
I guess, this is another escaping problem
"cmd /c if not exist \"C:\\Temp1\" mkdir \"C:\\Temp1\""
works on my PC
(770 Views)
