07-10-2009 05:35 AM - edited 07-10-2009 05:36 AM
which files/directories do i have to set for write access?
Normally windows-administrator can access everything.
But a windows-user has for example no write-acces to teststand\Cfg.
So sometimes i get the error-message that a file is write protected.
Is this somewhere explained in the TS-documentation that also a windows-user need write-access? I have this question from a client and i am not sure how exactly it is.
Thx for info
07-13-2009 08:56 AM
why don't you give write privileges to the whole TestStand folder?
Could you specify where your problems with the user privileges are?
Best regards
Rüdiger
07-22-2009 08:38 PM
Hi OnlyOne,
With TestStand 4.1 and later, we changed the directories for the TestStand Cfg folder and the TestStand Public folder (formerly called the TestStand Users Directory). These changes allow a normal Windows-User to write to the TestStand Cfg and Public folders without having to specifically grant write permissions.
