NI TestStand
Execute test uuts automatically
I want to execute Test UUTs in automatic mode (without clicking it) once run my LV Operator Interface, I've already loaded the right sequence file.
Thank you
Massimo Ponte.
(3,722 Views)
You could use the cmdline argument to the Operator Interface e.g.
textexec.exe /runEntryPoint "Test UUTs" c:\MySequences\MySequenceFile.seq.
See TestStand Reference Manual Chapter 8 Configuring TestStand.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,703 Views)
Thank you for the answer, I cannot try that because i load the sequence into my MMI after reading a configuration file.
Massimo Ponte.
(3,694 Views)
