NI TestStand
Executing Subsequences
Hi
I got a problem which im struggling to find a solution to.
What i got is a Sequence which calls two other sequence files using the sequence call step.
If  the execution option of the sequence call step is none , the sequence is called and traceses correctly but when the Test is complete the viewer displays the main sequence trace and not the trace of the subsequence.
I need it to display the subsequence trace.
So i tried setting the sequence call step execution option to New execution , it shows in the viewer like i want it to but it does not place the information into the database.
How can i call a subsequence and display its trace for viewing  after the test is complete(When using the operator sequence) and insert the information of the subsequence into the database?
Help share your knowlegde
(3,115 Views)
You need to place a Wait step at the end of your main sequence so that it capture the results of your new execution.
Regards
Ray Farmer
(3,111 Views)
You can also set the sequence call step to wait for the subsequence to complete in the advanced settings:
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,101 Views)
