NI TestStand
Execution time
I am using HTML reports. In report options "include execution time" adds or removed both module and execution time. Can the module time be removed and still log the execution time on report header?
(3,190 Views)
You can modify the 'reportgen_html.seq' file directly or modify the callback 'AddReportHeader'. In TestStand 4.0 the expression to add the Execution time had the following precondition:
Parameters.ReportOptions.IncludeTimes
You could unset the flag, in reportoptions,  to remove any MODULE times ( that is what I also do ) and REMOVE the above precondition to always specify the Execution time.
PH
(3,171 Views)
