NI TestStand
Export Sequence into a Database
Hello everybody,
Does anybody know if it is possible to export a Sequence into a Database without building the Table in the database first?
I mean, when I'm trying to export the sequence, I get an error because the UDL doesn't have a Table.
I create the Table, and then it doesn't have the right columns and so on.
Is there a way to "Build the Table" from Teststand and then export the Sequence into it?
I'm using Teststand 2019 32bits.
Thank you in advance.
Best Regards.
My Channel: https://www.youtube.com/@LV_Lab
(2,677 Views)
Accepted by topic author AldhairGarza
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsref/infotopics/propertyloaderplugins_dbformat/
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,621 Views)
Long time no see your Username Jiggawax! Thank you that is what I was looking for.
I also found that on the TestStand Help Library(?).
In case it is useful for someone else, there's also an example built in Access in the following path:
(2,615 Views)
My problem is that the database file that I downloaded composed of many files and not only the txt file. I downloaded the file from, unzip it and now I need to import it. Shouldn’t I import all the files in it?
(2,575 Views)
Which file did you download?
You should try with Property Loader [Step] I think.
But that's a different topic, you should definitely open a new post.
Regards.
(2,573 Views)
