Hi Thomas,
To obtain the name of the Step.Result.Measurement[0] you will have to use the NameOf expression or the API call PropertyObject.Name().
I have attached a TS2.0.x example. You will beable to view this in TS3.0. Althought TS3.0 Multiple Numeric Limit Test Steps have additional properties and therefore will probably error when you try to run this. It will error if you launch the Limits... dialog.
But the process is still the same.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
