NI TestStand
Export Typedefs from TestSTand to LabVIEW
Hi there,
is there a possibility to simply export a typedef made in TestStand to LabVIEW? I want to prevent making the same definitions twice.
Cheers
Oli
(3,390 Views)
No, unfortunately there is no mechanism to do this automatically.
The other way would be possible: If you have a cluster defined in LabVIEW, and use this as a parameter of your VI, you can automatically create a TestStand typedef for this cluster.
(3,371 Views)
Hi Andre,
that's what I feared Smiley Wink importing cluster definitions from LabVIEW into TestStand is out normal way, unfortunately this time we have an exception to the habit Smiley Sad
Thank you very much. Enjoy the public holiday Smiley Happy
Cheers
Oli
(3,355 Views)
