NI TestStand
Expression for an empty array
I want to reset an Array. Numeric 1D.
It's getting written on in my Sequence and when the sequence is ended I want to reset it as an empty Array. I want to do this through a statement. Can someone please send me the propper Expression I Need to use to make it empty again?
(4,844 Views)
Accepted by topic author Riesengross
Hello Riesengross,
You can just set the number of elements in the array to 0, with this kind of statement:
Locals.MyArray.SetNumElements(0, 0x0)
Make sure your sequence is handling properly the empty array you've just reset.
(4,821 Views)
Thanks, that worked.
Another easy way is, as I found out,
simply to write:
Locals.MyArray = {}
Simple assign Nothing like in SCALA.
(4,806 Views)
Funny. "{}" seems to be interpreted as an "Array of Numbers(64-bit Floating Point)". Whenever you try to reset an array of a different type than that, it won't work. At least not in my Value expression that I'm trying to pass as a Parameter into a subsequence.
Static typing for the win!
So tell me NI, what's the literal for "empty array of containers"?
(3,707 Views)
