NI TestStand
Exspression stament help
Hi
I got a message popup with a user input.
In the post exspression i tried the following an it does not work :
Step.Result.Status=Step.Result.Response,
Step.Result.Status == "" ? "Not Entered" : Step.Result.Response
Does anyone know why it is not working?
Help share your knowlegde
(2,951 Views)
All you are doing in that statement is setting the Step.Result.Status.
The second line is doing absolutely nothing.  What you want to do is this:
Step.Result.Status = (Step.Result.Response == "" ? "Not Entered" : Step.Result.Response)
You do not need the 2 lines if you do that.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,949 Views)
Thanks i always get confused with these statements.
(2,936 Views)
