NI TestStand
ExtraPutty TestStand API: ShowPutty parameter
Hello All,
I have been evaluating ExtraPutty's TestStand API for the last few days. It seems to work OK. The biggest issue that I have with it is that since I am using it in an automated test sequence I need to limit operator input as well as what windows are displayed. In order to not display my SSH Terminals I am setting the parameter "ShowPutty" to FALSE. The problem is that the terminal window is ALWAYS displayed regardless of what this parameter is set to.
Has anyone seen this issue before?
TestStand Version: 2013
ExtraPutty: SnapShot Release 0.29
*NOTE: Am not using the ExtraPutty TestStand step types but instead I am making calls to the c++ dll file.
Thanks!
-ES
(2,594 Views)
I'm not very familiar with this API, is the showputty option part of the API in teststand or is it something you're setting manually in showputty?
You might be better off reaching out directly to the API developers on this one. It seems like something specific to the API. and they'll have more specific knowledge of it.
Bill B.
(2,565 Views)
Thanks for the input. I've reached out to the developers with no response. Will try again.
(2,555 Views)
