NI TestStand
Extract Information XML Report
Hi
I want to extract the data from the TestStand XML Report using XML parser (Xpath) , but i am not able to get the expected results
Attaching the report file (not able to attach XML So changing the extension to .txt)
Want to Extract "/Reports/Report/Prop[6]/Prop[1]/Prop[1]/Prop[6]/Value[1...N]/Prop/Prop[6]/Value[1...N] "
I created Xpath in a usual way but it didn't worked form me
Can someone comment "what i am missing in achieving the expected result"
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,945 Views)
Post what you have. The code that's not working.
(2,936 Views)
Thanks for your interest in helping
As single Xpath is not working i have extracted the child items at different levels and achieved the result.
(2,931 Views)
