NI TestStand
Facing 307702 Error while deploying the sysdef file
Hi All,
I'm facing an issue while deploying the project file. The project contains six .dll files. Normally, I update the .dll in the system definition (.sysdef) file after making changes to any model without any problems.
Recently, I updated the inport name and signal name in one model (used for a simple switch). The new .dll integrates into the .sysdef file without errors. However, during project deployment, I encounter Error 307702, and the deployment fails.
What I’ve checked:
  1. The new .dll file is only 1 KB smaller than the previous version.
  2. The number of inports and outports remains unchanged.
  3. I removed and re-added the .dll in the .sysdef file.
  4. The "Import all parameters" option is enabled during model addition.
Despite these checks, the issue persists. Could you help identify what might be missing or causing this error?
Message 1 of 1
(55 Views)
