NI TestStand
Facing problem in calling the test sequence
Dear Members, Hope you all are doing good. I am new on TestStand, I am calling the sequence file and but the error mentioned appeared continuously, if I ran the given demos sequences without any problem but when i call my ATE equipment  sequence it shows the error. If call the project file again the same problem happens and VI calling from project appears as the empty dialog window. Looking forward to hear from TestStand community.
(566 Views)
The error message indicates, that the LabVIEW code can't be found.
Make sure, the code is available on your ATE at a place it can be found by the sequence file.
(540 Views)
