NI TestStand
Fail to Create VI at the Module tab of step settings block
As my attached video, my TestStand can't create VI at the Module tab of step settings block. It would always pop up error message as below:
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Error Code: -18002; LabVIEW reported an error. See 'LabVIEW :' message for more details of how to resolve this issue.
Is there anything missed in my TestStand environment? How can I fix this problem?
Message 1 of 1
(903 Views)
