NI TestStand
Failed to Load a required Step's associated module Err:-17600
the Issue was already solved by Me
Message 11 of 15
(2,392 Views)
Yes, I was just proposing an alternate solution, build "Release" versions of your dlls.
-Doug
Message 12 of 15
(2,386 Views)
Hi guys,
unfortunate as it may be, its a  dying  need to reopen this thread after  1 yr.
Using Testsand Ver 2012           labview 2012 f3
I find myself  tangled in a snake pit, This time the Situation is different ,  I am trying  to  use the Labview Runtime  with the Teststand Seq file  (another project).
I did a mass compile in the project & in Labview(Tools> Advanced >Mass compile)  Result ->> all well
The Seq. runs fine  when the labview  Adapter setting is  Dev system.
No sooner I switch the Labview Adapter to Run-time Engine  than starts the problem, "Failed to Load a required Step's associated module Err:-17600"
my prep
- the DLL mentioned in this thread(msvcr100d.dll) is present
- All paths are relative,
- search directories are clean
Any workaround or hint  for this newly found old  issue!!
Message 13 of 15
(1,717 Views)
Any solutiuon ?
@aparab wrote:
Hi guys,
my prep
Message 14 of 15
(973 Views)
msvcr100d.dll is part of the debug version of the VC runtime is not something you should be using on a deployed machine. You should be building the release versions of all of your dlls instead and then using the VC++ runtime redistributable package to install the release version of the vc runtime.
Hope this helps,
-Doug
Message 15 of 15
(956 Views)
