NI TestStand
Failed to locate Analog waveform Interface | Run-Time Error
I am getting this below run-time error message in TestStand 2019, when I pass waveform cluster data from LabVIEW2019 to TestStand.  I am using the default "LabVIEWAnalogWaveform" Type in Test stand.
Seems to be very simple & Straightforward. But I am getting the run-time error.  I didn't get solution from NI forum. Has anyone faced this issue before?
(1,793 Views)
Restart your computer and try to repair your LV installation.
Anand Jain
NI
(1,732 Views)
