NI TestStand
Fatal Error "... COM server cannot be marshaled ..."
I have a problem with a teststand (V3.1) sequence using on-the-fly report generation. After 13h of testing I get a reproducible error message "... COM server cannot be marshaled ..." (look at the attached screenshot). It doesn't depend on the system time, there is no other task running and I have enough free memory left. As you see in the screenshot, this error occurs during the execution of a ProcessModel sequence when a result is written into the temporary file. Because of the test duration (100h) we want to save the test results directly into a file in case of a computer crash. Using the normal report generation where the results are stored in the memory during the test sequence, we didn't get this failure.
Can someone give me a hint why this failure occures and how to prevent it?
System information:
Windows 2000 SP4
Teststand 3.1 (Deployment version, Labview Operator Interface)
Labview 7.1.1 Runtime Engine
Thomas
(3,155 Views)
Thomas,
since this error does not provide too much information on where the issue occurs, i can only guess. therefore, i have some questions for you which might lead the right direction:
a) Do you loop in your sequence for the whole testingtime?
b) How big is the file at the moment the error occurs? is it a very special size and it is always the same size?
c) Did you check CPU load?
d) Does the error always occur after a certain time (you said 13h after start) or does it differ? if it does, how big is the "window"?
Maybe this can clear up some things,
Norbert B.
Norbert
Expert: Geometry
(3,110 Views)
