01-14-2008 03:55 PM
01-15-2008 01:04 AM
When does this error occur:
When the OI is launched
or
when the Sequence File is executed. If when the Sequence File is executed can you pin-point it to one of your code modules?
Regards
Ray Farmer
01-16-2008 09:56 AM
Hello Ray,
Thanks for responding.
Got sidetracked on a hotter issue yesterday.
I am running under the sequence editor for now.
When I use the LabVIEW RTS it crashes and gives me the error but when I change to the TestStand LVRTS it says that one of my vi's is not executable, however I change back to the LV development environment and the vi is fine and all the subvi's are linked properly.
It does appear to be pointing in this direction, I will investigate further.
THANKS,
Kendrick
01-16-2008 04:10 PM
