NI TestStand
Features restricted with Evaluation Version??
Hello
i am using Test Stand 4.0 evaluation version, could you let me know that if it is possible to integrate it with clearcase for SCC, so that i can checkin the updates to the server.
Nitin
(2,817 Views)
Yes, it should be possible, SCC functionality is not limited in the evaluation version and clearcase is one of the supported source code control systems. You need to create a workspace with the files you want to use with source code control and set the correct provider (and possibly some other settings) on the properties dialog of the workspace. While the workspace is open you will then be prompted for checkouts when editing the files and you will have access to the other operations in the source code control menu and from the workspace view.
Hope this helps,
-Doug
Message Edited by dug9000 on 03-27-2008 11:02 AM
(2,803 Views)
