NI TestStand
Features
Hi all,
I am evaluating TestStand for a customer, which has special requirements. As I don't get an answer from NI itself, I try the forum.
Does TestStand natively support the following features:
  • Running a TestStand Develop System as master for create test sequences and starting/stiopping them on several Slaves running TestStand Base Deployment?
    There are up to 10 Slaves which can run 2-3 different tests (like 3 running Test1, 2 running Test 2 5 running Test3).
  • Is it possible to record measurement values like force and input current, which are not part of the test-step result?
  • As these tests running for a few weeks (run to death tests), can these recorded value be showed already during a test?
I am aware that such features can be programmed outside of TestStand by using LabVIEW and maybe triggered by TestStand, but the customer thinks of reducing time of such programming by using TestStand.
Thank you for your help.
Thomas Hoeltschi
(1,496 Views)
Hi, I will try to answer. Let me know if that helped:
  1. https://www.ni.com/docs/en-US/bundle/teststand/page/configuring-teststand-as-a-server-for-remote.htm...
  2. You can use "log" checkbox (Parameter Logging), Additional Results or simply Step.Result.ReportText. https://www.ni.com/en/support/documentation/supplemental/08/teststand-report-generation-and-customiz...
  3. Try this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9LdSAK&l=pl-PL. You need to be cautious with your memory usage if you what to keep it running for weeks. This potential problem was discussed here: https://forums.ni.com/t5/NI-TestStand/How-to-free-up-memory-while-executing/m-p/4057931#M62132
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,423 Views)
Hi Michał,
It helps me very much.
Best Regards,
Thomas Hoeltschi
(1,416 Views)
