NI TestStand
Files reported as modified during build
While trying to build a deployment I receive an error message about modified files, 846 of them. Some are mine but many are NI files for example:
C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Common Path to Specific Path.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Remove Quotes.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Unescape String.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Config Data RefNum.ctl C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Section.ctl C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Config Data.ctl C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Get Section.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Config Queue.ctl C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Typecast Queue to Refnum.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\New Config to Queue.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Typecast Refnum to Queue.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Get Section Names.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Get Key Names.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Config to String.vi C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\config.llb\Save Config File.vi
All of my files are in a complete different path c:\_view.... a ClearCase directory. Any of those I modified I checked out and checked back in. I haven't diddled with any of these files but suspect some dependency problem.
Any suggestions?
(3,041 Views)
jvh75021,
Couple of questions to help resolve this issue-
1. Can you please post the complete log file generated by Deployment Utility and also what version of TS are you using.
2. Are any of your VIs using VIs or controls from <vi.lib>\Utility\config.llb?
3. Can you reproduce this issue with a simple example?
Regards
Anand Jain
(3,022 Views)
