NI TestStand
Find all instance of sub sequence
I am using TestStand 3.5
I have created one sub sequence. I am calling this sub sequence at various places in my Seqence file. I found that the parameter value I am passing is wrong. I want to change it. Is there any way by which I can find out all the calling place of this sub sequence? How? (e.g. in LabVIEW we have Find all instances).
br,
LabVIEW_Vish
(3,240 Views)
Hey LabVIEW_Vish,
The best I got for you is to hit Ctrl-F and check Limit Search to:  Then you can choose All Sequences.  When you do your search you'll see a list of all the places where your search word exists.  Then you can double click on any element in the list and it will take you to that instance.   Your search window should stay open so you can go back to it Window>>Find 'keyword" in: etc..
Hope that helps some,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,229 Views)
Thanks Sam!
(3,211 Views)
