NI TestStand
Find and extract failing step Name to a local variable?
I would like to find the failing stepname and save it in a local/global variable.
Also I would get the execution time from a previous step and also save this in a variable.
>end of a sequence, get failing name to use in another function.
               Kris.
(3,140 Views)
Hi Kris,
Sorry for the late answer. I think this document can help you.
Let us know if it helps you.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,084 Views)
