NI TestStand
Find test socket index
Hi All,
I 'll try to explain better my needs.
I'm using simple GUI example of c# and I need for each event of "DisplayExecution" that occured what is the test socket index that referenced to it.
Please show me from which object should I get it.
private void axApplicationMgr_DisplayExecution(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_DisplayExecutionEvent e)
Tnx,
Liran
(6,060 Views)
DisplayExecution is not a good event for that because the socket is set in parallel in another thread, so it would be a race condition to access it from that event.
You should be able to use the UIMsg_ModelState_Initializing event, but there is a problem with that, which we will fix in a future release. Instead, you can use UIMsg_ModelState_BeginTesting:
void CTestExecDlg::UIMessageEventApplicationmgr(LPDISPATCH uiMsg, BOOL* cancel)
    UIMessagePtr message = uiMsg;
    if (message->Event == UIMessageCodes::UIMsg_ModelState_Initializing)
        int socketIndex = (int)message->GetNumericData();
        // this doesn't work, but will be fixed in a future release
    if (message->Event == UIMessageCodes::UIMsg_ModelState_BeginTesting)
        // this works, but note that you will get the message again for each UUT.
        // if socketIndex < 0, then it is not a test socket execution
(6,037 Views)
Hi James,
Maybe you know how to get the number of test sockets before start executing the batch by code.
I understand that it contains in "ModelData.ModelOptions.NumTestSockets" but how should I get it programmatically.
(6,018 Views)
You could call ReadModelOptionDefaults in ModelSupport2.dll (see http://forums.ni.com/t5/NI-TestStand/Get-the-Number-of-test-sockets-by-code/m-p/2710969#M44191). You can pass the function an empty container. When it returns, the container will contain a NumTestSockets numeric sub-property you can access with PropertyObject.GetValNumber.
(5,998 Views)
Assuming you are needing this in a C++ executable, you can avoid the need to link with modelsupport2.dll and the cvi runtime engine by just doing the following:
      // This assumes that TestStandModelModelOptions.ini already exists.
        IEnginePtr engine = mApplicationMgr->GetEngine();
        PropertyObjectPtr container = engine->NewPropertyObject(PropValType_Container, VARIANT_FALSE, "", PropOption_NoOptions);
        _bstr_t modelOptionsPath = engine->GetTestStandPath(TestStandPath_Config) + "\\TestStandModelModelOptions.ini";
        container->ReadEx(modelOptionsPath, "ModelOptions", RWOption_NoOptions, ConflictHandler_UseGlobalType);
        int numberOfSockets = (int)container->GetValNumber("NumTestSockets", PropOption_NoOptions);
(5,993 Views)
Thanks a lot,
It works perfectly.
(5,962 Views)
