NI TestStand
Finding occurence of a variable in a sequence file
I am debugging a sequence file and am looking for occurence of a variable throughout the sequence file.
Is this possible? (something similar to "find")
Your answer is appreciated.
Thank you.
(3,334 Views)
Edit >> Find...
Type in your variable name, limit search to your sequence (or as required).  Click OK.
(3,330 Views)
Thanks for the information.
I did not find this feature in TestStand version 2.0. I think this might be available in higher versions. Which TestStand version do you have?
(3,325 Views)
Unfortunatley, the Find option is available only in versions 3.0 or higher. Thank you Nandini Subramaniam NI
(3,308 Views)
