NI TestStand
Focus on popup text field
Hi!
Using Teststand 3.5 and its built-in message popup-function with response text-box enabled, I find it impossible to get automatic focus of the text box. To get focus and start inputting text I need to hit Tab or click in the text box. Anyway to get around this problem?
Thanks in advance!
(4,778 Views)
Did you set the Response as the Active control?
Regards
Ray Farmer
(4,771 Views)
Hi!
Thanks for your response!
Actually I missed that setting totally even though I've spent a few hours on solving this. I even made a dll to get the focus correctly set 🙂
Well, thank you for solving this for me. Can't believe I actually missed this.
(4,752 Views)
