NI TestStand
Forcing Single Pass entry point
Sorry.  Didn't mean to come of as patronising.  I was just letting you know that he did not want that as a solution and that it was already pointed out as a solution by him.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 13
(1,426 Views)
Hi Jigg,
Could you please elaborate on point 3?
"override the Process Setup callback and if the entry point was Test UUTs then kill the thread and start a new one using the Single Pass entry point"
I would like to achieve this.
Message 12 of 13
(871 Views)
@muthu4698 wrote:
Hi Jigg,
Sorry for the slow reply.  Been busy.
My idea was that you could override the process setup callback from the client and then check to see which entry point was executing.  Based on that you could kill the execution and relaunch to Single Pass entry point through the API or simply pop up a dialog and instruct the user to relaunch themselves using the single pass entry point.
I've attached a quick demo that i threw together.
Not sure I completely recommend it after putting it together but it will work.
jigg
CTA, CLA
testeract.com
Message 13 of 13
(845 Views)
