NI TestStand
Foreach
The ForEach Loop Edit Tab help states in part:
Array to Iterate Over—The expression that determines the array over which the loop iterates. The steps within the block execute once for each element in the array.
I would prefer that the steps execute once for each row. Is that not an option? The row elements are numbers and are provided to a VI. An alternative would be to put the elements in a container, then I would have a 1D array of containers.
jvh
(2,989 Views)
Duplicate post: http://forums.ni.com/t5/NI-TestStand/Foreach/td-p/1153817
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,971 Views)
