NI TestStand
General error handling operation
thanks for the advice. Actually, my error handler was derived from said example, I just left out the one case this post was about:-(.
Regards
Peter
Message 11 of 13
(1,284 Views)
@pwaszkewitz
Did the application engineer confirm your findings about the error handling?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 12 of 13
(782 Views)
Actually, we did not pursue this any further. The error handling was working to our satisfaction so we did not have much need to understand this one type of behavior. The only thing we changed is that we added the option to pass the error back to TestStand from StationPostStepRuntimeError (by not setting ErrorReported=true) because the original TestStand dialog offers an option which I think is only possible from a UI, not from a sequence, namely to break at exactly the point where the error occurred.
Regards
Peter
Message 13 of 13
(777 Views)
