NI TestStand
Generate Documentation of Custom Data Types
I'm using TestStand 2013. I have to defined a lot of Custom Data Types. Now I want to generate documantation for all this definitions including the data types, comments and so one (similar to Tools>Sequence File Documentation...).
Certainly I didn't find any ability in TestStand Editor to do that. Has anybody a tipp?
Kind regards
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(4,788 Views)
Hi Christian,
in sequence file documentation you can describe a lot of things. Like Variables and value display options;
what do you want to describe of the custom data types?
I thing the comment column should be enough for documentation.
best regards
Richard
(4,680 Views)
Hi Richard,
background of my request:
On development phase I want to editing type definitions in TestStand Types Window only, including detailed description in "Comment" input box.
After development I want to integrate the Types documentation in my customer model documentation. To aim that, I look for a possibility to export the Types from TestStand to clipboard or a csv file. It should contain
 - Name,
 - Type,
 - Default value,
 - Comment.
Then it will be easy to insert this table in a Word document or the like.
Kind regards
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(4,676 Views)
Hi Christian,
I think the easiest way is to drop all the custom step types in a Sequence and use then the Sequence file documentation.
Then you can copy/paste the information in a word document.
best regards
Richard
(4,581 Views)
