NI TestStand
Generate PDF report when test is finish
I want to generate a PDF report after every UUT is tested in my test bench in a specific location but i want to do that using the approach of printing it with Microsoft print to PDF because of limitation of software resources in the bench.
is that any thing i can create or develop either with changing the sequential model process or a by developing a VI in LabView.
when i run a sequence i notice that the report include the icone of printer and i can do the action of printing as a PDF.
help please,
Thanks in advance.
(1,304 Views)
The Report Generator plugin has an option to create a PDF.  I think this is available in TS 2019 and above.
Or you can use TestStand Model Plug-in: Printing Reports and Generating PDF Reports - NI Community for earlier versions of TestStand
(1,279 Views)
Thanks for your answer,
i have one more thing that when the report is generated the top margin is incorrect, the picture below shows in yellow that the Text is Cut-off so risk of losing some of the content.
how can i modify the margin to correct this issue.
thanks in advance
(1,240 Views)
