NI TestStand
Generate Test Report from database
Hi
How can i generate a Html Test Report from a UUT Test that i logged about a week ago?
Does Teststand have a pre built sequence for this?
Help share your knowlegde
(3,645 Views)
Has anyone generated a report on a Test Result stored in the database?
(3,630 Views)
Shako-
I see that you also posted this question in this forum.  As Taylor mentioned, there isn't a tool to generate a report from data in a database.  You can create a sequence to call into a database and then generate a report.  I would look at the example located at C:\Users\Public\Documents\National Instruments\TestStand\Examples\Database for reference.
Sean
Applications Engineering Specialist - Semiconductor Test
(3,618 Views)
When i realised that was from 2008 i made a new topic for this problem.
I am currently trying to create my own sequence to do this, I am just really suprised that there is nothing of the sort that is already out there.
Thanks for the reply.
(3,612 Views)
You can create a form to display you results from your database from the tools supplied with the database. You dont need Teststand to do this.
Regards
Ray Farmer
(3,610 Views)
