NI TestStand
Generating Run button click event programmatically in LabVIEW User Interface
I am using the Simple LabVIEW user interface(Simple OI - Top-Level VI.vi) for my teststand application with small changes. Here I don't want to CLICK the Run button every time. Can we generate the Run button click event(Which tringgers the TS engins) programatically in the user interfacr VI or is there any method to tringger the TS engins ?
More Info:
LabVIEW Ver: LabVIEW 2010
TestStand Ver: TestStand 2010 SP1
My sequence Run enry point is "Test UUTs"
Thank you
Adarsh
Adarsh
CLA - Certified LabVIEW
Architect
https://www.youracclaim.com/badges/4871da75-1b8b-422a-a881-9ab206d2d36d/public_url
(7,664 Views)
I other words,
I want to run my TestStand sequence file from LabVIEW UI dynamically(Say suppose comparison value is TRUE) without any user intervention
Adarsh
Architect
(7,663 Views)
Sorry I did not notice the spell mistakes 🙂
I am using the Simple LabVIEW user interface(Simple OI - Top-Level VI.vi) for my teststand application with small changes. Here I don't want to CLICK the Run button every time. Can we generate the Run button click event(Which triggers the TS engines) programmatically in the user interface VI or is there any method to trigger the TS engines ?
More Info:
Adarsh
Architect
(7,661 Views)
Accepted by topic author Adarsh
Hi Adarsh,
There is a DoClick method for TS UI buttons! Just wire the button ref to an invoke node and browse for the DoClick method.
Rodéric L
Certified LabVIEW Architect
(7,656 Views)
Its working 🙂 🙂 Thanks allot for the help.
Thank you
Adarsh
Adarsh
Architect
(7,653 Views)
Any time...
Rodéric L
(7,651 Views)
In my case, this does not work. UserInterface hangs when "Preloading modules" popup is shown...
(2,684 Views)
