NI TestStand
Generating report for Mainsequence & subsequences
Hi All,
Can someone help me to setup or config my teststand software for getting details of failed results for both main-seq and sub-sequences.
I can get the report for Limit test result OK if using in main-sequence however if I have all my Limit Tests in sub-sequence then calling it from main-sequence the report only indicated where is FAILED but not actual Test results.
(3,970 Views)
Hi NotHon,
Is your subsequence in a new thread? If so, this example should be relevant: https://decibel.ni.com/content/docs/DOC-5059
Humphrey H.
(3,957 Views)
@NotHon wrote:
Hi All,
The default behavior of teststand is to do what you are asking for, so perhaps you have disabled results in the subsequence or have otherwise made changes to the default behavior.
-Doug
(3,939 Views)
Hi All,
I already got my problem fixed but don't ask me why and how.
Basically I created a new subsequence and copy all the contents into it and bingo! all the test results are there.
Thanks for your input.
(3,923 Views)
