NI TestStand
Get Additional Results Names from Step
Hi to everybody. I would like ask for your help to achieve a task that has relationship with Step Additional Results.
I want to get the Name for additional results.
Currently I can get the values with the lookup string AdditionalResults and the invoke node get formated value but I need to get the names to build a string with the format: AdditionalResultName=>AdditionalResultValue;AdditionalResultName=>AdditionalResultValue;
The Names I am talking about are the next:
Thanks for the help.
(2,873 Views)
Not quite sure what you are looking for.  Does this help?  It just uses a lookup string to get the name and value.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,855 Views)
