NI TestStand
Get Comment from the Current Sequence
Hi everybody,
Just wanna know if it's possible to get the comment from the sub sequence like we can get the name using RunState.Sequence ?
my test Name is the sub sequence name and the number associated is placed in the comment, that way I'm generating data to database autmatically.
Pierre
(3,214 Views)
Hi Pierre,
you can use "RunState.Sequence.AsPropertyObject.Comment" to get the comment of your SubSequence.
Hope that helps.
Regards
MY
(3,210 Views)
Thx a lot ! it works ! 😄
(3,207 Views)
