NI TestStand
Get Current sequence opened from a Tools Sequence
Hi All,
I want to know if ti's possible to get a reference of the current opened sequence in sequence editor from a sequence launchend from the tools menu.
I want to build a generic tool to change some properties of any sequence opene. Place my tool in tools menu seems to be the easiest way.
Any suggestion ?
Thanks for your help
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
(2,211 Views)
Accepted by topic author MaximeR
Hi Maxime,
I believe the following reference will get you what you want: RunState.InitialSelection.SelectedSequences
I hope this helps.
-Jack
(2,177 Views)
@Captain_jack
Thanks a lot, you saved me a couple of hours.
Best regards
Maxime R.
(2,148 Views)
