NI TestStand
Get Name of Loaded Sequence File from Station Model
I want to query the test operator with a message box in my station model sequence file. I want the query to change based on which test sequence is loaded. Is there a way for me to get the name of the calling or loaded sequence file?
Curt
(3,453 Views)
Hi Curt,
If I understand your question correctly, which is that you want to display the sequence file that's being run by the Process Model Entry Point (or is selected by the operator), "RunState.InitialSelection.SelectedFile.Path" should get you what you're looking for. From there you can parse the string to get the file name.
I hope this helps.
-Jack
(3,440 Views)
You can also call RunState.ProcessModelClient.Path to get the path of the client file.
Or RunState.ProcessModelClient.AsPropertyObjectFile.DisplayName to get just the name of the sequence file.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,433 Views)
Thanks jig,
That worked with one minor change
ThisContext.ProcessModelClient.AsPropertyObjectFile.DisplayName
Thanks for your help
Curt
(3,431 Views)
To get the name and file path of the running sequence from the Station Model you can use the following statement command:
ThisContext.ProcessModelClient.Path
I have tested a verified this using TestStand 2016.
(3,126 Views)
