NI TestStand
Get SequenceContext (TS API) from LV
Hi!
I embedded TS interace in my LV code and would like to programmatically tune some settings of TS (Report, ...). Usually in TS I use RunState reference to get and set specific properties. It looks like RunState ref is not available through TS API => Am I wrong ?
It also looks like SequenceContext could allow me getting/setting interesting prop. But how to get ThisContext or SequenceText whithin LV ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,528 Views)
I use SequenceContext to get everything that RunState provides in TestStand.
You can pass in the SequenceContext to a VI to access it's properties and methods.  I would call a VI like this in your test sequence or process model.
PH
(3,521 Views)
Dear Teds,
The problem I'm not using a VI in TS. I'm using TS in a VI... I'm controlling TS through its API and I'd like to programmatically change options before lauching a custom TS behavior contolled by my software.
(3,516 Views)
Accepted by topic author CyGa
Hi Zyl,
You can access the Sequence Context from the ExecutionViewManager control and a Property Node, then, use property and invoke methode nodes to get or set the settings you want.
Olivier L. | Certified LabVIEW Developer
(3,476 Views)
