NI TestStand
Get TS_Err_DLLNotLoadable(-17004) using MFC Regular DLL
I made a regular MFC dll and tried to load it from TestStand 3.0. I got "-17004; Could not load DLL or library." Any ideas? Thanks.
(3,340 Views)
zZn -
There must be some dependency that the DLL has to another DLL that cannot be resolved or DLLMain is returning an error.  Use depends.exe to determine any DLL dependencies, and if you have defined a DLLMain, try to step through it to see what might be happening.
Scott Richardson
https://testeract.com
(3,329 Views)
It's the exactly the problem. Thanks a lot, Scott.
(3,320 Views)
