NI TestStand
Get a sequence file from list of part numbers
I would like to modify the TestStand Simple UI interface so that the operator can choose from a drop down list of part numbers that will then open the appropriate sequence file instead of browsing to open a file.  Is this possible?
(4,208 Views)
Hi OregonGumby
Does this snippet help you?
Beste regards,
Chris
(4,184 Views)
Hey OregonGumby, here are some other links that can help you get started
(4,168 Views)
I'm finally revisiting this.
I have some code that is working.  Sort of.
It does exactly what I want it to until I exit the VI at which point it gives me a TestStand Debug Warning window that says: References to PropertyObjects were not released properly.
Total number of objects: 2042
Number of top-level objects: 33
When I click the close button on this window, LabVIEW crashes.
If I compile and run it, it runs fine until I try to exit, at which point it hangs.
(4,068 Views)
OregonGumby,
Most likely there's an open reference in your program that you aren't closing correctly. I was able to find an article on our support site that goes into this error message in detail.
TestStand: PropertyObjects Were Not Released Warning When Using LabVIEW Code Module
http://digital.ni.com/public.nsf/allkb/C340060ECAFAA169862573C900723541
I would try reading that and then going through your code to double check that you're closing all the references you open.
I hope this helps.
Patrick O.
Applications Engineering
(4,054 Views)
