NI TestStand
Get name of step's sequence
Hi all,
I have a test sequence which consists of a group of sub-sequences.  Each sub-sequence contains a set of steps which report results to my report file.  I've created a custom callback sequence (ModifyReportEntry) in order to modify the report body text for each step, but I'd like to include then name of the step's sequence in the report line for that step.
I'm guessing that this property is somewhere in the Parameters.Result.TS realm, but can't figure out what it is.  (Using TS 4.1)
Can someone help me out?
Thanks!
Jeff
(3,199 Views)
Jeff,
general infos on how reporting works and how to customize can be found here.
A hint: The ResultList  contains all information you need if talking about subsequences (since it uses "Sequence Call" steps!)
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,192 Views)
Jeff,
You can use RunState.Caller.Parameters.SequenceName from your "ModifyReportEntry" Sequence File Callback. So the Statement expression would look something like Parameters.ReportEntry += "<tr><td>Sequence Name</td><td>"+RunState.Caller.Parameters.SequenceName+"</td></tr>"
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,174 Views)
