NI TestStand
Get pass/fail step status in a boolean led in LabVIEW
I want to know how I can get the status of a step in LabVIEW during the execution of a sequence, using the TestStand ActiveX engine(the sequence is executed in LabVIEW using the TestStand Simple UUI Interface for example).
(3,316 Views)
You should use UI Messaging to communicate between an executing sequence and the UI:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US
https://www.ni.com/en/support/documentation/supplemental/08/teststand-user-interface-development-bes...
If you want to get the status for every step then use the Post Step Engine callback and just post a UI Message with the result.
Let me know if you have any questions.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,310 Views)
