NI TestStand
Get running process model name
I'd like to test during the execution of my sequence
1) If there is a process model which has launched the sequence
2) The name of the process model which has been launched
Does someone knows the sentence ??
Cause i've tried this in a "if" step and it doesn't seem to work properly :
RunState.IsProcessModel && RunState.Execution.GetModelSequenceFile().AsPropertyObject().Name == "Single Pass"
(4,285 Views)
HI Nanor,
you should try this:
.... && StrComp(RunState.Execution.GetModelSequenceFile().AsPropertyObject().Name, "Single Pass") == 0
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,281 Views)
Hi Nanor,
forget the upper stuff!!
I was wrong, because it is the same!
You should use this expression:
RunState.Root.Sequence.Name
juergen
--Signature--
(4,276 Views)
Here's another version
PropertyExists("RunState.Root.RunState.ProcessModelClient") ? ("Process model is  " + NameOf(RunState.Root.RunState.Sequence) ) : "There is no process model"
cc
(4,265 Views)
Accepted by topic author nanor
Thanks a lot DowNow... It's working fine !!
(4,254 Views)
