NI TestStand
Get the Test Stand Report Filename
I would like to find the TS report filename, but DURING the test (ideally at the beginning of the main sequence).
I am generating several data files during the run, and I would like these files to have the same base filename as the report so that they match and can easily be determined.
I suppose another way to do this is to build the name from the start time.  If that's the case, can someone point out where that is kept?
(1,890 Views)
Accepted by topic author Jed_Davidow
Here I attached an example of how to do it.
Basically, it does following:
1. Searches for configuration of NI_ReportGenerator plugin in your model
2. Retrieves the full report path for your current socket
Roman
(1,852 Views)
I'll take a look, thanks!
(1,844 Views)
Fantastic!  And it helped me figure out how to search through the plugin list.  Outstanding!
(1,842 Views)
