NI TestStand
Get value from TSUI.I.Combobox
I'm trying to get the string value of the sequence that is currently selected in the "Sequence File Combobox". I've noticed this is a TSUI.I.Combobox and the Property Node for "Value" doesn't return the full path that is in the combobox.
Is there a way I can get the path?
(2,452 Views)
That's because the combobox is not a true combobox.  It is an activeX control and connects to a manager control.  The manager control talks to it and tells it what should be selected.  Or the manager control listens to it and when the user changes the selection then the manager control pushes that out to all other connected controls.
In order to get the path you need to use the SequenceFileView manager that the combobox is connected to.
SequenceFileViewMgr.SequenceFile.Path
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,400 Views)
