NI TestStand
Getting a User-input-acquering VI to show in test stand
Hi guys, I am trying to write a very simple test sequence file here.
The purpose is to prompt a user to enter some serial numbers manually, then automatically check if the serial number format is correct.
I have written a simple VI that asks the user to input the serial number, and included it in the sequence as a action step.
However, when the sequence executes, the user interface wouldn't pop-up.
Question is, how do I get that user itnerface to pop-up?
TIA 😃
(3,786 Views)
Did you check the 'Show Front Panel When Called' box? Did you include the Make Modal functions from the TestStand palette? Did you make the VI a dialog in the Properties>Window Options? Did you do anything to the VI?
(3,784 Views)
Thanks Dennis, problem sovled after I check the'Show Front Panel...' check box, and selected 'Activate when step complete' under Properties\Run Options\TestStand Window Activation
(3,768 Views)
