NI TestStand
Getting bin number
i am a beginner of Teststand and, i am using TS2017 now.
I wonder if there is anything that i can access to a bin number by expression or property?
I would like to get and use a bin number stored in a execution for Set and Lock Bin expression.
(3,203 Views)
Hi jonghkim,
 If you want to use "Set and Lock Bin expression"  function to reassign bin result, you can write your rule in preconditions. And how to decide the pin result is through your test result, so it's same means to do by that means to reassign bin result. Your rule can be based on two test results to reassign bin result. It's more customized for end user.
Ricky
(3,141 Views)
Hi, I would like to ask if there is any way that I can access the bin results of the unit that I've tested? I would like to make an action depending on the bin results, but I can't seem to find any expression to access them.
(2,762 Views)
Yes, you can get it from TSM api.
(2,744 Views)
